Ausbouw Radio
dg850 antwortete auf das Thema: Ausbouw Radio
Is there such a thing? Yes,normally problems... :mrgreen:
So you learnt something about the 8 series and will never forget :top:
Good luck at mount!
more pics about my car at the picture gallery :grinsen1:
#29726
  • Jelmer850i
  • Jelmer850is Avatar Autor
  • Fresh Boarder
  • Fresh Boarder
Jelmer850i antwortete auf das Thema: Ausbouw Radio
Radio is out..
The meganism was broken on the left side..
I did get out the whole part.. boardcomputer.. radio ... klimatronic part everything out.. so i could get the radio off.. but it's out ! 8)
I hope i can install the new radio/cd/dvd/mp3/tft tomorrow 8)
#29716
  • Jelmer850i
  • Fresh Boarder
  • Fresh Boarder
dg850: some other question.. do you have a picture of your complete interieur and doors ?
Beautifull black and white lether ! :top:
#29675
M6Achim antwortete auf das Thema: Ausbouw Radio
What a great cable salad. :mrgreen-angel: :top:
Achim
#29674
with 2 screwdrivers from the inside of the chute?
I have completed a lot of radios only with the lacing cords...
You have to make a break and drink coffee ,then cool at the work!
last resolution ist the sledge hammer :harhar:
#29671
  • Jelmer850i
  • Fresh Boarder
  • Fresh Boarder
bordcomputer ist aus...
But i cant get the fucking radio out of it :x , i've borrowed some original removal parts from a friend.. special for kennwood.
But the radio doesn't come out.. its as fast as a house..
I think the meganism isn't funcioning anymore.. i need to find an other solution to get the radio out..
Anyone a idee?
#29669
Take a look at the pictures and you will find the way ! :grinsen1:
At the back side of the radio you can find only the sensor from the alarm equipment,there´s no screw to affix the radio
You have to fumble something with the radio, it can sit a little fast.
I dont want to push my radio to make some pictures,it´s everytime a problem with the cables at the back side :flop: ,to much to fumble :harhar:
I´ll keep my fingers crossed!!! :top:
#29668
  • Jelmer850i
  • Fresh Boarder
  • Fresh Boarder
ok.. i did only tried above.. lets try again :mrgreen-angel:
#29667
some current pics
#29666
  • Jelmer850i
  • Fresh Boarder
  • Fresh Boarder
i did put in a ec-card but i can't pus the bc to the front..
#29663
  • Jelmer850i
  • Fresh Boarder
  • Fresh Boarder
thnx for the boarcomputer ! i will try it
But i tried to push something on de left and right from the radio.. but it doesn't work.
Sometimes you can mount the radio on the back ( anti thief ), with a screw.
Thanx !
#29659
Hi!
First you shold remove the bordcomputer(bc),take an ec-card and push it at the top-side of the bc between it and the plastic.There a some clamps you have to push and you can remove the bc,its very easy :grinsen1:
Now you can take a look inside,i think there´s no screw :shock:
Kenwood had to remove with an special tool, two metal pull-out hooks,also you could take 2 lacing cords and push it into the left and right side at the radio,so it will unblock the clamps of the mounting frame,in one fell swoop the radio is at your hands
Keep your hair on,you will make it! :top:
#29648
  • Jelmer850i
  • Fresh Boarder
  • Fresh Boarder
Jelmer850i erstellte das Thema Ausbouw Radio
Hello,
I need to remove my radio.. because ive bought a Radio/CD/MP3/DVD and 7" TFT 8)
But i can't remove the radio..
Its a kennwood.. 2 thin things on each side.. i put in there something.. but the radio doesn't go free..
I think its mounted als on the back ?? with a screw ?
How can i get there..
If i remove the whole panel.. the radio goes width.. but i cant get it enough to the front.. because the boarcomputer does hit the plastic above..
Please help..
#29641
