Relais ABS absent
soony antwortete auf das Thema: Relais ABS absent
Hi Danilo,
I don't have the contract, i have bought the car to a frenchman who has a previously bought the car in germany.
I've tried at my dealer, he can't access to the data because the car was german originaly. He can only access data to BMW sold in France.
My VIN number is CB10622 if someone can access to BMW data.
Vincent
330xd ~ 850iA
Membre Gold du Club E31.com
Membre du club 6enligne.net
#38521
Danilo antwortete auf das Thema: Relais ABS absent
ASC+T was optional for cars with automatic transmission.
So it should stay in the original contract of sale of your car, as:
214 ASC+T
If you don't have the contract, your official BMW dealer should be able to print the list of the optionals of your car. All you need is the VIN number (Vehicle Identification Number) CB*****.
#38520
a pic of my power distribution box
According ETM, if i have only ABS and ASC i must have the relay and if i have ASC+T and ABS, i didn't need to have the relay.
So, i must chek if i have ASC or ASC+T
Is there a sample way to check that?
330xd ~ 850iA
#38514
DaggiMicha antwortete auf das Thema: Relais ABS absent
Hi Soony!
What exact is your problem? Is your ABS without function, it is easy to test.
If your ABS is working, you have a relais. may be not at the place it should be,
but that doesn't matter, or?
Regards
André Gide
#38478
But, why the ETM says that i must have a relay?
and why in the empty socket, i've 4 wires?
I've found a reference on ETK, 34 52 1 179 131.
Someone with a 850iA of 1992 could look at his front power distribution box?
I've the sport M chassis, so, maybe the previous owner have remove the abs relay for more sport?
330xd ~ 850iA
#38473
dg850 antwortete auf das Thema: Relais ABS absent
I dont understand the problem....
Is there a mailfunction at the ABS,i dont think so,only a unused slot...
#38385
Hey Vincent don't worry about your english: it's quite good, and most of all waaay better than my French :D
So it looks like I can't help you just by looking into my fuse box in my car....
I'll see if I can get some answers in the German section ;)
Danilo
#38375
Hello Danilo,
on your 840, K10 shoud be Servotronic, not ABS
I've a control lamp in the cokpit, yellow-on at startup and off when running.
I've connectors in the empty emplacement at positions 2,5,6 and 8
	3:     :   -  :    :9
	2:  |  :   |  :  - :8
	1:     :      :    :7
In ETK, i've found 61 35 8 365 325 Relay ABS/ASC+T but connectors didn't correspond
In ETM, model 1993 didn(t use this emplacement.
But in ETM model 1992, this emplacement is used for ABS. (my 850 was buid may 1992)
Sorry for my poor english
330xd ~ 850iA
#38347
If that Relay K10 is really absent, it should cause a serious malfunction of the ABS system, therefore the contol-lamp in your cockpit should light.
As I believe you don't have any lamp burning, I really think this is absolutely normal and this empty place is just a kind of Place-holder (a sort of reserve).
BTW... why don't you just test it? You never did an ABS braking? :harhar:
All I can do is to watch myself in my car the next days... though I have an 840 and it could be a bit different...
PS sorry to write in english... I can't write a single word in french anymore.
I hope it helps nevertheless.
Danilo
#38343
soony erstellte das Thema Relais ABS absent
Bonjour à tous!
Je viens de me rendre compte que le relais K10 correspondant à l'ABS est absent sur ma 850iA de 1992.
Les broches sont pourtant présentes à l'emplacement.
C'est pareil sur les votres, ou bien le precedent propriétaire l'a enlevé? (il n'aurait pas voulu de l'ABS?)
Qu'en pensez vous?
Vincent
330xd ~ 850iA
#38336
